Recess Vent
Rashid_Garuba
Create a window, and dbl click to open it.
Under the general setting, change the window type to "Louvered".  Change the size to be the size of your vent.
Then under the options setting, change the recessed to whatever layer you prefer.
You can set other aspects of the vent however you want to make it more closely match what you've attached above.
What Jona-Thank did not explain very well is what your are recessing is the CASING.  Suppose you do not have casing,  you can control the recessing of the FRAME......  WINDOW DBX<FRAME,    A definite distinction.
Hey Jona-Thank,  see you in Idaho.
