RobUSMC Posted August 25, 2015 Share Posted August 25, 2015 Whenever I remove all the all the shelves from a cabinet it also remove the bottom floor of the cabinet which technically is not a shelf and part of the cabinet box. Same goes for the top of the cabinet. See attached. The only way I have found to work around it is to add two shelves with one 1/16" from the bottom @ 1/16" thick and just the reverse for the top. There must be a reason for this. Hopefully someone else has experienced this and knows the solution. thanks Link to comment Share on other sites More sharing options...
dshall Posted August 25, 2015 Share Posted August 25, 2015 Whenever I remove all the all the shelves from a cabinet it also remove the bottom floor of the cabinet which technically is not a shelf and part of the cabinet box. Same goes for the top of the cabinet. See attached. The only way I have found to work around it is to add two shelves with one 1/16" from the bottom @ 1/16" thick and just the reverse for the top. There must be a reason for this. Hopefully someone else has experienced this and knows the solution. thanks Not sure what the problem is. Link to comment Share on other sites More sharing options...
dshall Posted August 25, 2015 Share Posted August 25, 2015 ..... I bet you don't have a separation at the bottom. Link to comment Share on other sites More sharing options...
dshall Posted August 25, 2015 Share Posted August 25, 2015 ... and a separation at top... it's probably a problem with you cabinet defaults. Link to comment Share on other sites More sharing options...
dshall Posted August 25, 2015 Share Posted August 25, 2015 Here is my task, suppose I want to do what you did, how would I do that? Yea, how did you do what you did? Link to comment Share on other sites More sharing options...
RobUSMC Posted August 25, 2015 Author Share Posted August 25, 2015 There is a blank area at top and bottom not a seperation Link to comment Share on other sites More sharing options...
dshall Posted August 25, 2015 Share Posted August 25, 2015 There is a blank area at top and bottom not a seperation Okay, so what does that mean? Did you solve it? If not, do you want me to guess some more at a solution or do you want to post the problem cabinet. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted August 25, 2015 Share Posted August 25, 2015 I just had this happen recently. I just went back and looked at it and the condition still exists. I deleted one of the cabinets and reinstalled and no problem. Weird. Fortunately it was in a pantry closet and not part of the main kitchen I was doing some 3D work for so it didn't present a problem. I had installed the cabinets and stretched them just for plan view purposes. Not my design....... DiCaprio.zip Link to comment Share on other sites More sharing options...
RobUSMC Posted August 25, 2015 Author Share Posted August 25, 2015 I added a separation to the top and bottom but no change. Ill keep working on it. thanks Link to comment Share on other sites More sharing options...
