Sign in to follow this
KarenHamilton
Room defaults option missing
I used to be able to set floor and wall material options in the plan defaults.  Now, when I select Edit>Default settings>Rooms> and select, for instance, Kitchen/Bath/Utility Room, I only  see  a structure tab and am not able to set  materials.  Any idea how to restore the ability to set a default floor and wall material?    Thanks.
Floor finishes are still there right at the bottom, did you scroll down far enough?
Wall finishes would be under Wall defaults> materials though, not in the Room defaults
    27448
    dan_heidel
    dan_heidel
