Gawdzira Posted April 2, 2014 Share Posted April 2, 2014 On the temporary dimension string shown (version X6 latest update) the temp dimension is grabbing the outside of the wall for the window location. I am hoping there is a setting to make it grab the inside of the wall. Say it is so? Link to comment Share on other sites More sharing options...
DougMaddox Posted April 2, 2014 Share Posted April 2, 2014 Yes, this bothers me ALOT - hope there is an answer. Link to comment Share on other sites More sharing options...
Solution ebdesign Posted April 2, 2014 Solution Share Posted April 2, 2014 Might be in your temporary dimension defaults? Mine look like attached image. & I usually get what you want. It also matters where you click on the door/window where the temporary dimension appears- which side of the wall. Even w/ that, temporary dimensions don't always behave like I think they should. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 2, 2014 Author Share Posted April 2, 2014 Thanks Jim, I did not have the locate wall side set to Automatic and that did the trick. Link to comment Share on other sites More sharing options...
