connecting walk through cameras
Electromen
Is there a trick I'm missing?  When I created a Walk Through Path, I have a hard time connecting the cameras.  I'll start out alright but after a few turns, it wants to create a new set of cameras.  After several tries it works but it's frustrating.
Greg I do the whole path and after using Add Key Frame tool I add as many cameras along the path as I need and face them any which way you want, adding extra cameras around the turns for smoother turning.
I hope it helps.
That's a good idea, I'll give it a try.
I tried drawing a walkthrough path and editing it with keyframes.  I doesn't allow me to curve the path the way I'd like to.
I tried a spline, the walkthrough works but a spline doesn't allow for editing individual camera views.
Greg, when you get your walkthrough path drawn use the break (#3key) to break the path and you will have additional handles to curve it or shape it any which way you like and you can add more breaks and cameras as you go to get the path you need.
