Boxon1
Go to solution Solved by HumbleChief,
Hi everybody,
I need a help - again.
I was playing with settings, and committed suicide.
I changed something in (probably) reference floors display setting, so, now when reference floor display is activated, it doesn't shows just thin red lines, but entire content of reference floor - including material fills, furniture, text, dimension lines, just everything. That makes such a huge mess on screen, that any work is impossible with "reference floors" on.
I tried to set that back in layer management, but reference floor layer set looks just normal, as on other plans.
If I start New plan, it works as it should 0 showing just thin red lines.
Any ideas what I did and how to set it back?
I attached three screenshots - first floor, second floor and second floor with reference ON. As you can see, it's an ugly mess, specially since I have a habit of using all kind of CAD lines as temporary stuff, so now there is just too much on the screen.
Bockey
