Paramount Posted May 19, 2015 Share Posted May 19, 2015 Hi, I read the other threads and still got no idea why my ceilings are not showing in X7. I have everthing turned on? See attached. SPEC 1.zipFetching info... Link to comment Share on other sites More sharing options...
rlackore Posted May 19, 2015 Share Posted May 19, 2015 Your plan contains no data - be sure to close the plan before zipping or uploading it. Link to comment Share on other sites More sharing options...
Paramount Posted May 19, 2015 Author Share Posted May 19, 2015 Ok got it, now I know. My curved exterior wall is also giving me issues generating studs.sills? SPEC 1 (curved great).planFetching info... Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted May 19, 2015 Share Posted May 19, 2015 YOu have no finished ceiling! Check your structures tab and ceiling. Link to comment Share on other sites More sharing options...
rlackore Posted May 19, 2015 Share Posted May 19, 2015 As Dennis noticed, add a finished ceiling and assign it a material. For some reason when I add a finished ceiling the material automatically assigned is Insulation Air Gap - you need to change this to a material that isn't defined as Gap. Link to comment Share on other sites More sharing options...
rlackore Posted May 19, 2015 Share Posted May 19, 2015 If you want framing for the curved wall just select it and RIGHT CLICK>BUILD FRAMING FOR SELECTED OBJECT. Link to comment Share on other sites More sharing options...
Solution Paramount Posted May 20, 2015 Author Solution Share Posted May 20, 2015 Got it thank you very much! For the other noobs I changed my default floor/ceiling finish setting then each room spec to use default. Having the ceiling parameters in floor defaults is confusing! I'd like a ceiling default. Link to comment Share on other sites More sharing options...
