Ed_Orum Posted 11 hours ago Share Posted 11 hours ago Good morning, I want to export my entire user library as .dwg and .dxf files. Is there a way to select the entire user library and export the whole thing at the same time, or do I have to do each file individually? Thanks in advance, Lane Link to comment Share on other sites More sharing options...
DBCooper Posted 9 hours ago Share Posted 9 hours ago The only way you can export your user library directly from Chief is as a calibz type file. If you want to convert your library objects into dwg/dxf files, you need to do that from either a plan view or camera view (depending on whether you want 2D or 3D data). Depending on the types of objects you want to convert, this could also be very "lossy". There may be some ways you can automate this (using scripts or maybe even ai) but you will probably have to jump through some hoops. So this begs the question, why? Link to comment Share on other sites More sharing options...
