Gawdzira Posted August 28 Share Posted August 28 Is anyone having issues with the latest update when sending elevations to layout? I might need to paste everything into new template files? This could be legacy plan issues as I am pretty sure this plan started in an earlier version than x18 beta. it was working in the beta version and then before the update yesterday. Link to comment Share on other sites More sharing options...
Eric_S Posted August 28 Share Posted August 28 2 hours ago, Gawdzira said: Is anyone having issues with the latest update when sending elevations to layout? I might need to paste everything into new template files? This could be legacy plan issues as I am pretty sure this plan started in an earlier version than x18 beta. it was working in the beta version and then before the update yesterday. Could you post the plan please? Link to comment Share on other sites More sharing options...
Gawdzira Posted August 28 Author Share Posted August 28 (edited) If you look at the plan view I have 2 polylines in light yellow highlighting 2 elevation cameras. The plan was hanging up on the bad camera. I made a new camera and now it works. It is likely this is a legacy plan camera issue. Using a new layout from a template or an older layout that I started the project in has no impact on the hanging up issue. https://www.dropbox.com/scl/fi/4xhbx1senqzuptg3a405i/Lugo-DD-V1e.plan?rlkey=dv4k0jj8g8e0godwsv0clceuj&dl=0 Edited August 28 by Gawdzira Link to comment Share on other sites More sharing options...
Eric_S Posted August 29 Share Posted August 29 31 minutes ago, Gawdzira said: If you look at the plan view I have 2 polylines in light yellow highlighting 2 elevation cameras. The plan was hanging up on the bad camera. I made a new camera and now it works. It is likely this is a legacy plan camera issue. Using a new layout from a template or an older layout that I started the project in has no impact on the hanging up issue. https://www.dropbox.com/scl/fi/4xhbx1senqzuptg3a405i/Lugo-DD-V1e.plan?rlkey=dv4k0jj8g8e0godwsv0clceuj&dl=0 I didn't have the same issue sending that camera to layout. If the problem reoccurs please let us know. Link to comment Share on other sites More sharing options...
wkshank Posted September 15 Share Posted September 15 I'm having the same issue with elevations hanging up just while I've got their window open and adding dimensions, lines, etc -- even before sending to layout. I also get hangup when creating or manipulating solids/slabs in camera mode. Grrrrr... Thinking I may have to re-create all the work I did today and put this plan back into v.17 to get this out to the client in time. Hours of repeat work. : ( Link to comment Share on other sites More sharing options...
