Copying note labels from one elevation to another
Larry_Sweeney
Go to solution Solved by PitMan71,
I have two different elevations. I want to place the same note label on each elevation referring back to a single note. Is there a process to do this. I've tried looking for a video or knowledge base explaining the procedure, but so far I haven't found how or if it's possible. I know you can easily copy a note label in the same elevation, but I'm not having any luck copying from one elevation to another. I thought I had done this before, but then again, maybe not.
  • Solution
You will likely need to use copy (ctrl-c) and then paste (ctrl-v). Basically the same as what "Rookie65" said. The copy tool wont stay invoked outside the view its started in. You can use the copy and then use paste under edit to paste it in your new view. There are several ways to accomplish this. Give it a go and let us know if it works.
