Larry_Sweeney Posted August 17 Share Posted August 17 I have two different elevations. I want to place the same note label on each elevation referring back to a single note. Is there a process to do this. I've tried looking for a video or knowledge base explaining the procedure, but so far I haven't found how or if it's possible. I know you can easily copy a note label in the same elevation, but I'm not having any luck copying from one elevation to another. I thought I had done this before, but then again, maybe not. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 17 Share Posted August 17 (edited) Try copy on one elevation, then paste >hold position on the next. I do it on every plan Edited August 17 by Rookie65 Word change 1 Link to comment Share on other sites More sharing options...
Solution PitMan71 Posted August 17 Solution Share Posted August 17 You will likely need to use copy (ctrl-c) and then paste (ctrl-v). Basically the same as what "Rookie65" said. The copy tool wont stay invoked outside the view its started in. You can use the copy and then use paste under edit to paste it in your new view. There are several ways to accomplish this. Give it a go and let us know if it works. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted August 17 Share Posted August 17 I find that paste >hold position works just fine from one elevation to another Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted August 17 Author Share Posted August 17 Keith & Shane....................Thanks to you both. Yes they both work. I'm much appreciated. I would almost swear I use to just click on one, hit copy, go to another elevation and paste. Whatever works though, is what I'm after. Have a great day! Link to comment Share on other sites More sharing options...
