Under Stair Storage Built in
KBEDesign
49 minutes ago, KBEDesign said:
@winterdd This is exactly what I'm going for! How did you get the base cabinet to insert into the walls? I have drawn the wall under the stairs, but I can't get the base cabinets to set into the walls.
He only drew the walls where he needed them. There are no walls where the cabinets are
You may have bumps turned off, either turn off bumps and place your cabinet or hold the ctrl key when moving your cabinets to override bumps
