JKEdmo Posted Wednesday at 06:21 PM Share Posted Wednesday at 06:21 PM Curious how someone would go about modeling these windows below. Window openings in masonry wall with shallow arched lintel, but with rectangular retrofit windows. My first thought is maybe arched pass-through window on top of a standard window, but just a guess. Thanks again, Jim Link to comment Share on other sites More sharing options...
glennw Posted Thursday at 02:13 AM Share Posted Thursday at 02:13 AM (edited) You can do that with a Wall Material Region using Cut Finish Layers of Parent Object. So...place a standard square topped window and then in elevation view draw the Wall Material Region to the shape you want to cut out the arched brickwork above the window. Edited Thursday at 02:20 AM by glennw Link to comment Share on other sites More sharing options...
JKEdmo Posted Thursday at 02:55 AM Author Share Posted Thursday at 02:55 AM 41 minutes ago, glennw said: You can do that with a Wall Material Region using Cut Finish Layers of Parent Object. So...place a standard square topped window and then in elevation view draw the Wall Material Region to the shape you want to cut out the arched brickwork above the window. Glenn, Thanks for the tip. I'll give it a try tomorrow! Have a great day. Jim Link to comment Share on other sites More sharing options...
