Ed_Orum Posted June 9 Share Posted June 9 Here is a screenshot of my problem. It appears an additional foundation slab and walls are generating below the foundation. The door drops down the the 2nd foundation floor. Upstairs the absolute floor elevation is 16", because this floor sits 16" above the main existing floor. It appears the upstairs heights are set correctly, but the foundation level is a real problem. The plan is attached. Thanks in advance for any help! --Lane Apollino Remodel Plan 2026.zip Link to comment Share on other sites More sharing options...
JonathanK Posted June 9 Share Posted June 9 (edited) It's your 2X6 walls that you have on the inside of your foundation. They are creating little micro rooms between the framing wall and the foundation wall. Anywhere they connected to the foundation wall, you had another room. They were locked as well, so you cannot select them. Once I deleted those, it looked better. I would add a new wall type for your foundation that includes all the layers of that 2X6 wall on the "inside" layer of the foundation wall type. Either that, or drag one of the 2X6 walls away from the foundation wall, adjust the room floors, and then drag it back. You might have to do that multiple times until you get all the "hidden rooms". It all depends on how you do your layouts, and plan sets. Edited June 9 by JonathanK Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 9 Author Share Posted June 9 Thanks! I never would have figured that out! --Lane Link to comment Share on other sites More sharing options...
madcowscarnival Posted June 10 Share Posted June 10 You might open the dialog on those inside walls and select "furred wall". That way you can drag it right against your foundation wall, and it doesn't create any room between the 2x6 and foundation. Link to comment Share on other sites More sharing options...
Ed_Orum Posted June 23 Author Share Posted June 23 Thanks! Link to comment Share on other sites More sharing options...
