DRyeHD Posted 3 hours ago Share Posted 3 hours ago (edited) I'm doing an addition for a customer and they want to see a 3D model of the whole thing. I thought I could do this within the CA software, and I'm sure I can, but don't know how. I'd like to do an exterior flyover and include both the as built and the remodel. I didn't know how to go about searching the disscussions on something like this. Could someone steer me in the right direction? Edited 3 hours ago by DRyeHD add to explanation Link to comment Share on other sites More sharing options...
JKEdmo Posted 3 hours ago Share Posted 3 hours ago 5 minutes ago, DRyeHD said: I'm doing an addition for a customer and they want to see a 3D model of the whole thing. I thought I could do this within the CA software, and I'm sure I can, but don't know how. I'd like to do an exterior flyover and include both the as built and the remodel. I didn't know how to go about searching the disscussions on something like this. Could someone steer me in the right direction? Damon, You might find something of use in Chief's tutorial video section. That's where I'd start at least. https://www.chiefarchitect.com/videos/watch/19/virtual-walkthroughs.html?playlist=102 Jim Link to comment Share on other sites More sharing options...
Rookie65 Posted 2 hours ago Share Posted 2 hours ago (edited) How did you draw the plan? Did you draw the existing, and then the addition? I save one version as the existing. Then I will copy the plan as the proposed and draw the addition on to it. Then you'll have the full house. If you've drawn them as separate plans, you should be able to copy and paste all of floors from one to the other. The kicker will be if the floors are on different levels. Meaning if the 1st floor is not set to "0" on both plans, aligning will be difficult. Edited 2 hours ago by Rookie65 Word change Link to comment Share on other sites More sharing options...
