Ed_Orum Posted February 28 Share Posted February 28 When I drew a plan and did a "save as" it was my intention to use that plan as a template, because it had pages and pages of boilerplate notes, sections, and 2025 Code Notes. I also did a "save as" for a layout file that had all of the notes, etc. on different sheets. It was my intention to use that as a Layout template. My thought was open the plan file, use "save as" in a New Folder and also use a "save as" for the layout in the new folder. That seemed logical and straightforward to me. Since all of my files are kept in Dropbox, they naturally got uploaded automatically. However, when opened the files from Dropbox on a different computer, half of the CAD files were missing. What gives? Is it just me or does anyone else have problems with file management in Chief? Link to comment Share on other sites More sharing options...
Solution para-CAD Posted March 1 Solution Share Posted March 1 I have found, and was educated by someone smarter in chief than me, that you have to hit SAVE first on your files that you want to later SAVE AS. this exact thing happened when someone I was helping thought we should have a backup copy to the plan so we hit save as. This was all done locally on his machine and not in dropbox. He lost quite a bit of time and work. The solution would’ve been to hit save on the original files to make them updated, and then save as and you would have two identical copies at the same work state. 1 Link to comment Share on other sites More sharing options...
Ed_Orum Posted March 4 Author Share Posted March 4 I ended up downloading two other plans that this plan used. Then everything populated. Now I know. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 8 Share Posted March 8 On 3/4/2026 at 3:16 PM, Ed_Orum said: I ended up downloading two other plans that this plan used. Then everything populated. Now I know. also this might help you: 1 Link to comment Share on other sites More sharing options...
