Drawing walls with interior dimensions only
Scvide
I want to be able to draw walls based on interior dimensions.  Not studs, not from the outside of the wall, but as if I am standing in the room and have taken manual measurements.
I have tried interior walls, but every time I drag a second wall perpendicular from another wall it add the thickness of the second wall to the first wall drawn.  I don't want that to happen.  Is there a way to create walls within instead of adding to the outside?   In the attached image, I want the red, not the default grey.
Try this:
Open up your "general wall defaults".
Change the "resize about" setting to "inner surface".
Now as you draw a wall and see the temp dimensions, they should show you the interior surface-to-surface  length.  Same if you open up the wall dialog and look at the length.
You may also want to change your dimension defaults so that they will locate wall surfaces as well.
Thank you.  I got the first part..
I am looking in the Dimension Edit Settings and can't seem to find the second suggestion.  Can you give some direction?
Also, when I drag the walls, the only dimensions I see are the ones at the very bottom of the screen.
