dhurst Posted 5 hours ago Share Posted 5 hours ago Can anyone help me with inserting built-in (Sub-zero) refrigerator into a tall cabinet. For some reason since switching to X17, the refrigerator sits in front of the cabinet . Link to comment Share on other sites More sharing options...
MollyNDG Posted 5 hours ago Share Posted 5 hours ago The way fixtures insert into cabinet faces has changed in X17. If you open up the cabinet -> Front/Sides/Back -> Appliance and select Edit you can adjust the amount the fixture inserts into the Cabinet Front (Options, Select Inserts into Cabinet Front and enter a value). 1 1 Link to comment Share on other sites More sharing options...
DBCooper Posted 3 hours ago Share Posted 3 hours ago You can also just place the refer as a free standing appliance and build the cabinet(s) that go around it. You will probably run into the same issue with dishwashers. Link to comment Share on other sites More sharing options...
PitMan71 Posted 2 hours ago Share Posted 2 hours ago This forum thread may be helpful. Its for a DW but might help with this fridge situation too. Link to comment Share on other sites More sharing options...
