automated scheduling of CAD DMS info
Brady33
Project export and screen shots
Good day,
I'm a builder and draft my own work.  I'm trying to streamline getting the data for my site work of laying out foundations.  I use a theodolite with DMS and a tape to lay out the footings and then pin the block corners for my masons.  Assembling the data to do this is cumbersome.
On the foundation layer I use a CAD line to draw from XY 0,0 to all the corners of the foundation block.  A CAD line easily presents the distance and angle but doesn't seem to have information that can extrapolated to a schedule.  The first question is:  Can that be done?  Can I build a schedule to get CAD Line's information?
I've tried using a general framing member and can get the formatted distance into the schedule but I can't figure out the macro to get angle into the schedule.  There is clearly Angle information for general framing members (as seen in the screen shot), but if I run a Object Properties macro on the framing member, there is no "angle" macro.  Object Properties on a CAD line results in evaluation error.
I've included the pictures and .caproj in the link as it's too large to upload directly.
Thanks for your time and consideration.
foundation_DMS.thumb.jpg.a8b4fc7f5076a9793b3c8e06d9e1f860.jpgframing-member-dialog.thumb.jpg.107c2c4dd6e8e3f2692bd3f925c4594f.jpg
Thanks Coop.  We also figured out sprinklers work.
Fun fact:  8yo Brian Ingram, the kid that found some of DB Cooper's cash in 1980, lives in the same town as me, Mena, AR.  He's doing well, lays flooring for a living and still gets contracted to go to events and show off a few burnt bills the FBI let him keep.
Update.
I still can't get the Angle information into a schedule unless it's on a 2D Symbol.  Then the line is so small you can't see the angle on it.  You can't use a Room Divider as it's snap and connects to a wall.  The line needs to snap to a foundation/block corner to give correct length and DMS.
