Fotis1960 Posted 17 hours ago Share Posted 17 hours ago Hey Everyone Why is the wall details separating the framing of the wall and the girts to layer 2 and 3.(picture attached). And why are the wall studs that I entered manually not showing. Are they supposed to be on layer 5? Everything is on Wall, Normal layer. Thank you in advance. Andys Pole Building.zip Framing.pdf Wall Detail.pdf Link to comment Share on other sites More sharing options...
