Relating to layer display sets
Evolution
I am working on setting up layer sets (set some up in the edit default tools menu) and noticed that even though I have built a couple of different layer sets, copied from existing sets, with the associated layer's displayed, I want for each, I noticed that there is not an option (at least I haven't found it) to see the new layer available in the layer window (if that makes sense?). You have to select a layer, open, the look for the newly created Layer Set and it's associated layers to display, and I haven't done enough using the different layer options to know how to access them easier. I'm sure the experts on here have it all down to a science but I don't. I'm using CA 12 a lot more now (in semi-retirement) and just getting back up and running, thus the need to have a better workflow. Is that where "saved plan views" comes in? IF so, I'll probably not live long enough to learn to do it that way.
image.thumb.png.dedfed34162e046e3119d60695877b28.png  image.thumb.png.f6ad56e6262994fc4030a04adb8ac89a.png  image.thumb.png.02039a575a2f1434e056e7655530c06e.png The layer set I want is not in the project browser either. image.thumb.png.27ad64a963f124418ed4836a8f7314bf.png
Edited by Evolution
Add new comment
Yes. You definitely should start using SPVs, check out the training videos:
https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html
https://www.chiefarchitect.com/videos/watch/2433/developing-saved-plan-views.html
https://www.chiefarchitect.com/videos/watch/10199/productivity-tips-saved-plan-views.html
309246599_Screenshot2026-01-08at10_41_57AM.thumb.png.82dfa00a1c4b2535ef5adccd7e57a396.png
3 hours ago, Chrisb222 said:
Chris, I've actually watched these videos several times and also the video's related to as-built drawings.  I've created several "saved plan views" and within each have attempted turning on and off the particular items I want displayed for each saved plan. That being said, I can't quite get the trick doing the over-lay of the as built to new construction. I'll leave things as they are for now and go back and watch the "Remodeling: How to Generate As-Built Overlays in 2D & 3D - Video | Chief Architect" again.
    image.thumb.png.dacdf6bb1789f88ea8d9f2d21b830344.png image.thumb.png.a125a4958dd4d4aa369174f257958123.png
image.thumb.png.f094f86fbdf582c2ed2deb23bdc8fb44.png  image.thumb.png.fd8a1e0c1f7df7e1b2379a813ee4548a.png
