Evolution Posted Thursday at 02:43 PM Share Posted Thursday at 02:43 PM (edited) I am working on setting up layer sets (set some up in the edit default tools menu) and noticed that even though I have built a couple of different layer sets, copied from existing sets, with the associated layer's displayed, I want for each, I noticed that there is not an option (at least I haven't found it) to see the new layer available in the layer window (if that makes sense?). You have to select a layer, open, the look for the newly created Layer Set and it's associated layers to display, and I haven't done enough using the different layer options to know how to access them easier. I'm sure the experts on here have it all down to a science but I don't. I'm using CA 12 a lot more now (in semi-retirement) and just getting back up and running, thus the need to have a better workflow. Is that where "saved plan views" comes in? IF so, I'll probably not live long enough to learn to do it that way. The layer set I want is not in the project browser either. Edited Thursday at 02:55 PM by Evolution Add new comment Link to comment Share on other sites More sharing options...
Chrisb222 Posted Thursday at 03:43 PM Share Posted Thursday at 03:43 PM 56 minutes ago, Evolution said: Is that where "saved plan views" comes in? Yes. You definitely should start using SPVs, check out the training videos:https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html https://www.chiefarchitect.com/videos/watch/2433/developing-saved-plan-views.html https://www.chiefarchitect.com/videos/watch/10199/productivity-tips-saved-plan-views.html Link to comment Share on other sites More sharing options...
Evolution Posted Thursday at 07:49 PM Author Share Posted Thursday at 07:49 PM 3 hours ago, Chrisb222 said: Yes. You definitely should start using SPVs, check out the training videos:https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html https://www.chiefarchitect.com/videos/watch/2433/developing-saved-plan-views.html https://www.chiefarchitect.com/videos/watch/10199/productivity-tips-saved-plan-views.html Chris, I've actually watched these videos several times and also the video's related to as-built drawings. I've created several "saved plan views" and within each have attempted turning on and off the particular items I want displayed for each saved plan. That being said, I can't quite get the trick doing the over-lay of the as built to new construction. I'll leave things as they are for now and go back and watch the "Remodeling: How to Generate As-Built Overlays in 2D & 3D - Video | Chief Architect" again. Link to comment Share on other sites More sharing options...
