Ed_Orum Posted December 31, 2025 Share Posted December 31, 2025 I opened the dialog box for the dormers, and set the walls at 82". When I dimensioned the plan view, none of the dormer walls were at 82". Apparently for Dormers the locate wall dimension surface does not work, and the 82" dimensions to the siding. Is there a setting to make the walls in the dialog box to reflect the actual outside wall to outside wall instead outside siding to outside siding. Thanks in advance and Happy New Year! Link to comment Share on other sites More sharing options...
PitMan71 Posted January 1 Share Posted January 1 I looked into this.... I see what you are referring to... The only way that I can find to do this is to do the math and make the adjustment or explode the dormer. If not exploded you can't dimension to the dimension layer of the walls in it. The only way I could find to dimension it was to drag grips to it and that wasn't attached to the wall dimension layer. The dormer tool is really nice. These improvements would make it better and more useful, IMO. Link to comment Share on other sites More sharing options...
Solution MoeGia Posted January 6 Solution Share Posted January 6 I oversize the default dimensions to allow for this 'bug'. The auto dormers do not follow the default dimension settings as far as I can tell. That said, I usually just create them automatically; it's faster and more accurate for me. Link to comment Share on other sites More sharing options...
