make simple shape an electrical object
madcowscarnival
Go to solution Solved by DBCooper,
Hey folks,
I'm certain I've done this before, but cannot recall how.  Is it possible to make a simple shape (i.e. a 12" CAD circle) into a generic electrical object that I can then connect with the electrical connect tool?
I've looked at the "covert polyline..." options, but nothing gets me to an electrical object that the program will recognize.  I'm unable to come up with appropriate search language to get my answer.  Is this possible or am I mis-remembering?
  • Solution
If you have a 2d circle, you need to first convert it into a 3d disk or cylinder.  You can use the convert polyline tool to make a 3d solid or slab.  Then you should be able to use the convert to symbol tool to make it into an electrical object.
