madcowscarnival Posted December 8 Share Posted December 8 Hey folks, I'm certain I've done this before, but cannot recall how. Is it possible to make a simple shape (i.e. a 12" CAD circle) into a generic electrical object that I can then connect with the electrical connect tool? I've looked at the "covert polyline..." options, but nothing gets me to an electrical object that the program will recognize. I'm unable to come up with appropriate search language to get my answer. Is this possible or am I mis-remembering? Link to comment Share on other sites More sharing options...
PitMan71 Posted December 8 Share Posted December 8 You will need to create a symbol. A symbol allows you to assign it Electrical Properties. However, I don't see a way to do that with 2d lines. Someone else might know that trick. Link to comment Share on other sites More sharing options...
Solution DBCooper Posted December 8 Solution Share Posted December 8 If you have a 2d circle, you need to first convert it into a 3d disk or cylinder. You can use the convert polyline tool to make a 3d solid or slab. Then you should be able to use the convert to symbol tool to make it into an electrical object. 1 Link to comment Share on other sites More sharing options...
madcowscarnival Posted December 8 Author Share Posted December 8 Thanks for the replies. DB, that was the series of steps I was trying to remember. Something I haven't used in years, just couldn't recall. 1 Link to comment Share on other sites More sharing options...
