Ed_Orum Posted 8 hours ago Share Posted 8 hours ago Hello This screenshot is from the right elevation view. There is a box on the second floor, left side where two windows show in the floor plan view. Why won't they show in the elevation view? I placed the windows with copy/paste of the windows that do show up in the same elevation view. Thanks in advance, Lane Link to comment Share on other sites More sharing options...
JiAngelo Posted 8 hours ago Share Posted 8 hours ago Check to make sure lower walls are aligned. Link to comment Share on other sites More sharing options...
DBCooper Posted 8 hours ago Share Posted 8 hours ago One possible cause is that your window is on the wrong floor. Make sure the window is on the same floor as the wall as it is shown in your plan view. Could also be a problem with wall alignment (as John suggested) or modified wall tops/bottoms. If you can't figure it out, then you should post the plan. Link to comment Share on other sites More sharing options...
Ed_Orum Posted 6 hours ago Author Share Posted 6 hours ago Thanks. First I looked to see if the windows were on the correct floor. They were. Then I made sure the walls lined up with each other. They did. But The problem was the lower wall was broken into two parts. Once I connected them the problem solved itself. Thanks JiAngelo and DB Cooper. Link to comment Share on other sites More sharing options...
