capitaldesigns Posted November 20 Share Posted November 20 I am working on plans for a new hillside house. I've imported a PDF of the grading plan I received from the civil engineer. I'm tracing over the existing contour lines using the elevation lines and assigning each line the elevation shown on the grading plan. When I view the plan in perspective view I see some very high peaks in the terrain. I don't know why this is happening. I've attached the plan in a zip file. Does anyone know why this is happening and how I can fix it ? Thanks, Mike Anderson Design Plan 5.zip Link to comment Share on other sites More sharing options...
mtldesigns Posted November 20 Share Posted November 20 check one of your elevation lines is 0. See if that helps Link to comment Share on other sites More sharing options...
mtldesigns Posted November 20 Share Posted November 20 7 minutes ago, capitaldesigns said: Does anyone know why this is happening and how I can fix it Actually, two things. Your lines are not connected AND the one side is at 0" See vid Recording 2025-11-19 203634.mp4 1 1 Link to comment Share on other sites More sharing options...
capitaldesigns Posted November 20 Author Share Posted November 20 Thanks Michael. That was the problem. I did not catch that contour line was broken into 2 lines. Link to comment Share on other sites More sharing options...
mtldesigns Posted November 21 Share Posted November 21 10 hours ago, capitaldesigns said: Thanks Michael. Your welcome Michael. Glad I could help. 1 Link to comment Share on other sites More sharing options...
