XpandRDIV Posted November 19, 2025 Share Posted November 19, 2025 Just when I think I've seen it all...I am working to design a closet system. Should be a piece of cake, but throw in the mix that that 2/4 walls in the closet are radiused. I can see how to make a radius front on a cabinet, but is there a way to make a radius BACK so that the cabinetry will butt nicely to the wall? Right now, it's a bunch of boxes that are sort of snapping to the wall, but it looks like a nightmare. Tips/tricks? Thanks in advance! Link to comment Share on other sites More sharing options...
DBCooper Posted November 19, 2025 Share Posted November 19, 2025 Are you going to actually make cabinets with curved backs? If not, then just place straight back cabinets and use a custom curved counter to hide the gaps. If so, then you can make a curved back cabinet by making a curved front cabinet with the opposite curve and butt it up against the other one. You can then remove the face that is against a wall. Link to comment Share on other sites More sharing options...
XpandRDIV Posted November 19, 2025 Author Share Posted November 19, 2025 Good question--custom cabinetmaker has assured me he can work with the walls, so yes--I believe that the cabinets will actually have curved backs. I think I'm more concerned with the clients seeing the wonky floor plan as I have it now than anything. It doesn't look terrible in renderings, just requires a little "creative" camera work. Thanks for the tip--I'll give that a try! Link to comment Share on other sites More sharing options...
Renerabbitt Posted December 3, 2025 Share Posted December 3, 2025 On 11/19/2025 at 12:49 PM, XpandRDIV said: has assured me he can work with the walls I would say with 99 percent certainty that your cabinets will be flat-backed... No reason to ramp up the cost of a unit 500% for something that will never be seen or utilized. Hope that helps 1 1 Link to comment Share on other sites More sharing options...
