XpandRDIV Posted 9 hours ago Share Posted 9 hours ago Just when I think I've seen it all...I am working to design a closet system. Should be a piece of cake, but throw in the mix that that 2/4 walls in the closet are radiused. I can see how to make a radius front on a cabinet, but is there a way to make a radius BACK so that the cabinetry will butt nicely to the wall? Right now, it's a bunch of boxes that are sort of snapping to the wall, but it looks like a nightmare. Tips/tricks? Thanks in advance! Link to comment Share on other sites More sharing options...
DBCooper Posted 8 hours ago Share Posted 8 hours ago Are you going to actually make cabinets with curved backs? If not, then just place straight back cabinets and use a custom curved counter to hide the gaps. If so, then you can make a curved back cabinet by making a curved front cabinet with the opposite curve and butt it up against the other one. You can then remove the face that is against a wall. Link to comment Share on other sites More sharing options...
XpandRDIV Posted 8 hours ago Author Share Posted 8 hours ago Good question--custom cabinetmaker has assured me he can work with the walls, so yes--I believe that the cabinets will actually have curved backs. I think I'm more concerned with the clients seeing the wonky floor plan as I have it now than anything. It doesn't look terrible in renderings, just requires a little "creative" camera work. Thanks for the tip--I'll give that a try! Link to comment Share on other sites More sharing options...
