Need help creating a window.
Dutchworks
  • Dutchworks changed the title to Need help creating a window.
You can get pretty close using a "fixed door" by setting the bottom of the frame larger and making 2 vertical lites.  If you need it to look more accurate, you would need to use a door symbol.
7 hours ago, Dutchworks said:
Can someone point me in the right direction for creating a window like this? I'm using CA X14. I will get a better picture later today.
You might be able to do this as a vertically stacked mulled window.  Top window double hung / bottom window with solid panel (change glazing material to opaque).  At least that's the approach I'd take.
Jim
