SC_drafting Posted October 31, 2025 Share Posted October 31, 2025 Does anyone know how to get rid of these X's? They still display if I turn off electrical objects. It only happens in elevations, as shown. Hope it'll be an easy one.Electrical X problem.pdf Link to comment Share on other sites More sharing options...
Designers_Ink Posted October 31, 2025 Share Posted October 31, 2025 (edited) Open the light fixture dbx and uncheck the "Show Position in camera view" for each light. Edited October 31, 2025 by Designers_Ink Link to comment Share on other sites More sharing options...
Solution DBCooper Posted October 31, 2025 Solution Share Posted October 31, 2025 (edited) Are you using the latest update for X17? I saw something in the update notes that was about light position indicators that wouldn't always go away. If you aren't using the latest update, then you probably want to get it. If turning them off using the update doesn't make them go away, then you should post your plan. Edited November 1, 2025 by DBCooper Link to comment Share on other sites More sharing options...
SC_drafting Posted November 1, 2025 Author Share Posted November 1, 2025 Designers_Ink, I looked in the dbx and it was already unchecked. I'll get it updated tonight and see if that fixes it. Link to comment Share on other sites More sharing options...
SC_drafting Posted November 5, 2025 Author Share Posted November 5, 2025 Fixed! Thanks. Link to comment Share on other sites More sharing options...
