Red X's on Electrical Objects Problem
SC_drafting
Go to solution Solved by DBCooper,
  • Solution
Are you using the latest update for X17?  I saw something in the update notes that was about light position indicators that wouldn't always go away. If you aren't using the latest update, then you probably want to get it.  If turning them off using the update doesn't make them go away, then you should post your plan.
Edited by DBCooper
