CoolHandLuke Posted 17 hours ago Share Posted 17 hours ago This use to work when I would lower the door but does not work now. Any ideas what I could be doing wrong? Thanks! Link to comment Share on other sites More sharing options...
SHCanada2 Posted 16 hours ago Share Posted 16 hours ago i just did one yesterday. is the room a "garage". attached garage walls here are typicallyy12" or so concrete above grade(plus below grade frost walls), so there always needs to be a cutout I did have the room below on the foundation set to be a crawlspace...which did not work. Changed it to garage and it worked Link to comment Share on other sites More sharing options...
Rookie65 Posted 16 hours ago Share Posted 16 hours ago Do you have the rough opening set to "show in room below"? Link to comment Share on other sites More sharing options...
CoolHandLuke Posted 12 minutes ago Author Share Posted 12 minutes ago Yes I have the Rough Opening set to show in room below Link to comment Share on other sites More sharing options...
