dshall Posted October 18 Share Posted October 18 Hi All, this is the Recessed window test, See picture, note the space between windows Group 1 on left: flush stucco between windows, simply 3 windows with space between each Group 2 in middle: stucco appears to protrude between windows, simply 3 windows with space between each BUT THESE ARE BLOCKED, but why does it protrude? Group 3 on RIGHT: RECESSED MULLION/SPACER between windows, How would you build this? 1 Link to comment Share on other sites More sharing options...
DBCooper Posted October 18 Share Posted October 18 When you block windows, Chief will put in an extra piece between them that it calls a "mullion". You can control how much it sticks out (or recesses) by opening the mulled unit dialog and changing the "mullion depth". I *think* it will always use the same material as the casing. 1 Link to comment Share on other sites More sharing options...
dshall Posted October 18 Author Share Posted October 18 6 minutes ago, DBCooper said: When you block windows, Chief will put in an extra piece between them that it calls a "mullion". You can control how much it sticks out (or recesses) by opening the mulled unit dialog and changing the "mullion depth". I *think* it will always use the same material as the casing. HI DB, I could not find the mulled unit dialogue box, would you please let me know where it it located? Here is another pic with 3 different options. One of the options is the "BUCKED WALL" look. (something I could not figure out years ago. Link to comment Share on other sites More sharing options...
dshall Posted October 18 Author Share Posted October 18 I found it, but the wood sill shows up... Link to comment Share on other sites More sharing options...
DBCooper Posted October 18 Share Posted October 18 It looks like if you pull the mullion in too far you will get a hole in your wall when you don't have any casing. You could try doing something lame like turning the casing back on and making it only 1/16" wide but this might give you a double line that you may not like. Others may know some better work-arounds but you might want to post the plan for them to play with though. Link to comment Share on other sites More sharing options...
