Aligning objects
jorgearaya
The 'make parallel' tool is really the simplest option. First rotate the polyline so the desired edge is close to parallel with the intended object. Then, click on the desired edge, then double-click the 'make parallel tool and select this option:
Then click on the target object.
This is genius. It will save me hours of head scratching.
