HumbleChief Posted April 9, 2015 Share Posted April 9, 2015 I'm afraid to close down X7 with the task manager as I don't know how much work I might lose. Time to call Tech Support I'm thinkin'. http://www.screencast.com/t/Iidnw2pxrH Link to comment Share on other sites More sharing options...
builtright3 Posted April 9, 2015 Share Posted April 9, 2015 That's a new one on me. I would be afraid of losing info also. I got locked out today and lost a lot of info and had to start over. If your hooked to a second screen you may be able to drag over to start the second screen and possibly it my split up your program enough to hit save. Long Shot! Link to comment Share on other sites More sharing options...
builtright3 Posted April 9, 2015 Share Posted April 9, 2015 I guess the second screen wouldn't help because it wont allow you to get out of the box. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 9, 2015 Author Share Posted April 9, 2015 Talked to tech support and had to end the application in task manager. We went through a few hoops to get everything back but all is well. Hope this helps someone in the future. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 9, 2015 Author Share Posted April 9, 2015 I guess the second screen wouldn't help because it wont allow you to get out of the box. I did try that Joey and appreciate the tip but everything including the second monitor was locked up with that text box. Tech support had seen it once before and hitting the escape key got rid of it but not this time. Link to comment Share on other sites More sharing options...
builtright3 Posted April 9, 2015 Share Posted April 9, 2015 Let me if you loose your info after you restart or whatever you have to do. I'll be curious about that because I lost mine today? Link to comment Share on other sites More sharing options...
builtright3 Posted April 9, 2015 Share Posted April 9, 2015 Talked to tech support and had to end the application in task manager. We went through a few hoops to get everything back but all is well. Hope this helps someone in the future. I didn't see this post. Glad everything worked out! Link to comment Share on other sites More sharing options...
