gravattedesign Posted September 8, 2025 Share Posted September 8, 2025 My User Catalogue suddenly was lost during a work session. X16 pro version. The content was migrated from X15 when X16 was installed. I do not have a screen shot of the error that occurred but there was a fail error that popped up, then the content was gone. Is there a way to reconnect a User Catalogue in the library browser? I opened X15 and the User catalogue is gone/disconnected there as well. Thank you for any help. Windows 10/64bit/CA-X16Pro Steve Link to comment Share on other sites More sharing options...
Solution PitMan71 Posted September 8, 2025 Solution Share Posted September 8, 2025 The most likely cause of this is a change in the path to your catalogue. I would find where it's stored and reestablish connection. If you have to restore from a backup. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted September 8, 2025 Share Posted September 8, 2025 See if this helps ( I think most of it still works for X16): https://www.chiefarchitect.com/support/article/KB-00090/obtaining-and-updating-library-content.html If not, then you can always call tech support but not sure if it will be free or not since you are on an older version. Link to comment Share on other sites More sharing options...
gravattedesign Posted September 13, 2025 Author Share Posted September 13, 2025 Pitman and DBCooper.. Thank you for the responses. I'll give both recommendations try and report back. Best regards, Link to comment Share on other sites More sharing options...
gravattedesign Posted September 13, 2025 Author Share Posted September 13, 2025 Gentlemen, Success! On both your recommendations. The "Preferences/General/Folders/User Library folder" was pointing to the installed default path. I found my previous User_Library.calib file in a custom folder that was established in X15. Double clicked on the *.calib file and all content was restored to X16 Library. I then changed the preferences/User Library Folder path to search my custom folder. Last part of process was included to aid in the exact method of recovery for anyone else that finds this helpful. Thank you again. 1 1 Link to comment Share on other sites More sharing options...
DCB123 Posted March 29 Share Posted March 29 Hello; I too have now noticed that my "User Libraries" have disappeared suddendly in all of my versions of Chief, as I even opened the preferences in this version X17, and then older versions, say, X11. I need your help pls, in trying now to find a way to restore my User Libraries from the Preferences, or from another data point from the cloud or the Chief software itself....? Any help or support here is greatly appreciated. Thanks agin. Link to comment Share on other sites More sharing options...
PitMan71 Posted March 29 Share Posted March 29 I am pretty sure you will find all of your folders under "Documents". You are looking for a folder called "Chief Architect Premier X16 Data" where the X16 is the version of chief you have installed. I would make sure those folders exist or didn't somehow get remapped transparently without you being aware.... In my case this happened when I set my Mac to sync with iCloud. Suddenly everything was missing. This is because in order for things to sync with iCloud, they had to be in a certain folder and therefore "documents" was remapped by macOS to the new folder. Once I reset the folder path location in Chief everything sorted itself out. If the data folders exist check the actual "documents" folder path and compare with what is in chief. if you don't know how to do that a quick google search should suffice. Link to comment Share on other sites More sharing options...
