PitMan71 Posted August 29, 2025 Share Posted August 29, 2025 Is there a way to remove or turn off the roof trim from a selected roof edge? This would be on an edge that abuts a wall. Thanks Link to comment Share on other sites More sharing options...
Chrisb222 Posted August 29, 2025 Share Posted August 29, 2025 1 hour ago, PitMan71 said: Is there a way to remove or turn off the roof trim from a selected roof edge? This would be on an edge that abuts a wall. You can select roof trim if you unlock its Roofs, Trim layer (locked by default on stock templates). You can then perform some edits to the molding.... which can get quite glitchy and entertaining, depending. Good luck! 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted August 29, 2025 Author Share Posted August 29, 2025 47 minutes ago, Chrisb222 said: You can select roof trim if you unlock its Roofs, Trim layer (locked by default on stock templates). Thanks for the info.... I have used this when editing trim... You are correct "glitchy" is putting it mildly.... For some reason I want to say I remember seeing something to turnoff trim on an edge somewhere. Must have dreamed it. Link to comment Share on other sites More sharing options...
SMCDesign Posted August 30, 2025 Share Posted August 30, 2025 If you're referring to shadow boards, select the roof plane by selecting the edge that you want to modify. In the "Roof Plane Specification" window go to the "Shadow Boards" tab. At the top of the window there are options under the "Shadow Board On Selected Edge" section. 1 Link to comment Share on other sites More sharing options...
