wncbw7 Posted August 13, 2025 Share Posted August 13, 2025 My county's GIS system exports a folder containing files in this format: DBF, PRJ, SBN, SBX, SHP and SHX How can I convert or import the information in these files. I am looking for the parcel and terrain information. This is for the rare occasion that there is no surveyor where I can get the CAD file from. I am using X17, and do not have Autocad. Link to comment Share on other sites More sharing options...
PitMan71 Posted August 13, 2025 Share Posted August 13, 2025 What GIS system are you using? Shane Link to comment Share on other sites More sharing options...
robdyck Posted August 13, 2025 Share Posted August 13, 2025 Paste the text below into a web search. Then follow some of the links to find out which converter works for you. DBF, PRJ, SBN, SBX, SHP and SHX convert to gpx Link to comment Share on other sites More sharing options...
wncbw7 Posted August 13, 2025 Author Share Posted August 13, 2025 I dont know what system the county has. I am just using Chief Link to comment Share on other sites More sharing options...
PitMan71 Posted August 13, 2025 Share Posted August 13, 2025 1 hour ago, wncbw7 said: I dont know what system the county has. I am just using Chief If they have ESRI ArcGIS Pro, you can open the file (.shp or shape file) that you are referring to and export to a cad file or maybe even gpx file that can then be imported into Chief. EDIT: I looked and you can export .gpx from ArcGIS Pro. See here... https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/features-to-gpx.htm Shane Link to comment Share on other sites More sharing options...
