PitMan71 Posted August 6, 2025 Share Posted August 6, 2025 Hey guys.... Is there some secret to rotating many objects at one time? In this case it's a detached garage. I have spent too much time trying to demystify the code. Seems like there are some items that when selected they make the rotate handle disappear. Anyway, any tips on that process? Thanks in advance. Link to comment Share on other sites More sharing options...
PitMan71 Posted August 6, 2025 Author Share Posted August 6, 2025 I think I figured it out. There was a piece of moulding that was creating the headache or so it seems. Link to comment Share on other sites More sharing options...
Solution ChiefTylerL Posted August 6, 2025 Solution Share Posted August 6, 2025 @PitMan71 For scenarios like this I would recommend using the Edit Area tools. These tools allow you to highlight an area and then move/copy/reflect/etc everything that is contained within that selection. These tools are found by going to Edit> Edit Area Some information can also be found in this article: https://www.chiefarchitect.com/support/article/KB-02917/rotating-a-structure-or-plan-view.html I hope this helps! 1 1 Link to comment Share on other sites More sharing options...
PitMan71 Posted August 6, 2025 Author Share Posted August 6, 2025 I will give that a shot. Thanks Link to comment Share on other sites More sharing options...
mtldesigns Posted August 7, 2025 Share Posted August 7, 2025 4 hours ago, ChiefTylerL said: Edit Area tools @PitMan71 I agree, this is really the only way to rotate a lot of objects at once. Make sure to pick "Edit Area (all floors)". This will get you the foundation, roof and any other floors not shown. I use this also for a move command too. 2 Link to comment Share on other sites More sharing options...
PitMan71 Posted August 7, 2025 Author Share Posted August 7, 2025 Thanks all. Link to comment Share on other sites More sharing options...
PitMan71 Posted August 8, 2025 Author Share Posted August 8, 2025 Edit Area tool is awesome. Thanks for the tips all. Shane 1 Link to comment Share on other sites More sharing options...
