MN_JohnH Posted July 7, 2025 Share Posted July 7, 2025 I have been going through this plan and i can't figure out why the floor joists always frame as I-joists. I have set the defaults and room floor structures, everything i can find. I have turned off auto framing. I can change individual joist to framing but they change back when I reframe the floor. And why is my subfloor sheathing showing as strips on top of the joists? I know this is something simple again but I can't figure it out. I am using x17, (I know I need to change that in my signature). Floor joist problem.plan Link to comment Share on other sites More sharing options...
mtldesigns Posted July 7, 2025 Share Posted July 7, 2025 28 minutes ago, MN_JohnH said: And why is my subfloor sheathing showing as strips on top of the joists I haven't got x17 loaded yet.. but I can answer this. Go to your floor structure definition, item 1 should be your sheathing. Make sure "Framing" isn't checked. Matter a fact, this same dbx, see how your item 2 should be is marked.. this determines your joist style. 3 Link to comment Share on other sites More sharing options...
MN_JohnH Posted July 7, 2025 Author Share Posted July 7, 2025 10 minutes ago, mtldesigns said: I haven't got x17 loaded yet.. but I can answer this. Go to your floor structure definition, item 1 should be your sheathing. Make sure "Framing" isn't checked. Matter a fact, this same dbx, see how your item 2 should be is marked.. this determines your joist style. Ahh... you have to do it for each material. Dang. I know I have been through this before, hopefully I can remember next time. Thanks Michael! Link to comment Share on other sites More sharing options...
mtldesigns Posted July 7, 2025 Share Posted July 7, 2025 7 minutes ago, MN_JohnH said: Thanks Michael! NP.. glad I could help. Link to comment Share on other sites More sharing options...
