Chiefnewell Posted Thursday at 03:27 PM Share Posted Thursday at 03:27 PM How do I send Architectural floor plan and electrical floor plan to same layout sheet? When I have one above the other, they both are the same. 36x24 Layout.layout 4417 Tilson.John Randall.zip Link to comment Share on other sites More sharing options...
StephenGreene Posted Thursday at 03:42 PM Share Posted Thursday at 03:42 PM 14 minutes ago, Chiefnewell said: How do I send Architectural floor plan and electrical floor plan to same layout sheet? When I have one above the other, they both are the same. 36x24 Layout.layout 539.7 kB · 1 download 4417 Tilson.John Randall.zip 5.37 MB · 1 download not exactly sure what you mean, but if it's what i think it is, try unchecking the Linked Saved Plan box on each before sending to Layout. that will keep them from being the same. Link to comment Share on other sites More sharing options...
DBCooper Posted Thursday at 04:29 PM Share Posted Thursday at 04:29 PM I didn't look at your plan but I am sure that Stephen is correct in that both layout boxes are using the same saved plan view (or at least using the same layer set). You can either break the link to the saved plan view like Stephen suggested or setup two different saved plan views so that they are independent. You might want to take a look at this info on saved plan views: https://www.chiefarchitect.com/support/article/KB-03185/understanding-saved-plan-views.html https://www.chiefarchitect.com/videos/watch/2421/saved-plan-views.html Link to comment Share on other sites More sharing options...
Chiefnewell Posted Thursday at 08:56 PM Author Share Posted Thursday at 08:56 PM I have worked out the 2 plan views-Electrical and Architectural going to layout sheets. Fire restoration project, City of Houston. Link to comment Share on other sites More sharing options...
