QuickDraw59 Posted June 25, 2025 Share Posted June 25, 2025 Our Interior Designer would like a clean floor plan view showing the various flooring texture (line graphics) so Clients can sign-off. I have selected one of the un-used Layers and turned things on/off to declutter. How can I get flooring patterns? Is that possible in X16? I've attached a sample graphic of flooring textures that is like what I need. Thanks! Link to comment Share on other sites More sharing options...
Rich_Winsor Posted June 26, 2025 Share Posted June 26, 2025 17 hours ago, QuickDraw59 said: How can I get flooring patterns? Have a play with the Fill Style in the Room Specification DBX. 2 Link to comment Share on other sites More sharing options...
robdyck Posted June 26, 2025 Share Posted June 26, 2025 I'd suggest that you explore the Orthographic Full Overview camera, then select 3d>View Direction>Top View. This will display the pattern used for the material. To adjust the pattern lines, simply edit the material (if needed). Experiment with rendering styles and toggling color / shadows, etc. 2 Link to comment Share on other sites More sharing options...
