Double brick wall with opening...
koreyd77
I'm back and getting into Chief again after a 5 year break. I use to be on the Beta team, but I need my training wheels for now... I thought at one time their was a way to wrap brick, siding, stucco ext.. when it is double sided for an opening? Thanks for the help!!
The only way I can think of to accomplish that is to change the jamb material of the opening to brick and make the jamb thickness the same as your brick thickness. You would also want to remove the casing unless that is a brick detail. Doing that should display in plan how you are wanting it to. Worth a try anyway.
  • 4 months later...
On 10/31/2025 at 6:55 PM, joey_martin said:
Remove all jamb, casing, etc and the brick should wrap.
I have never had success getting the brick to wrap on the plan view even when doing these ideas. Any other ideas? 3d view looks correct with brick showing.
