JKEdmo Posted June 24 Share Posted June 24 Good morning, I have an exterior balcony (1) over a framed pop-out fireplace (2) with a manual roof plane that is affecting the balcony's soffit finish (3). Pretty sure this is because I'm building a room over a roof plane, which I believe Chief does not like judging by the forums. Any setting I can use to fix this, or should I just patch it with a 3D solid for example? Thanks again, Jim Link to comment Share on other sites More sharing options...
Solution robdyck Posted June 24 Solution Share Posted June 24 First thing I'd try is unchecking 'Roof Over This Room' in the lower pop-out room. Second thing I'd do (if that doesn't work) is add that layer to the floor structure specification for the balcony. Link to comment Share on other sites More sharing options...
JKEdmo Posted June 24 Author Share Posted June 24 32 minutes ago, robdyck said: Second thing I'd do (if that doesn't work) is add that layer to the floor structure specification for the balcony. Robert, Success! I added a finish layer to the underside of the floor assembly to patch things up like you suggested. Thanks! Jim 1 Link to comment Share on other sites More sharing options...
