ACADuser Posted June 24 Share Posted June 24 Main roof is cantilevered trusses with 24" overhang. One 10' section needs to be a shed roof over a pop-out. How do you mix flat soffits & sloped soffits in the same roof plane? Or do I need to create another roof plane over that section? I built the framing in that area manually. Link to comment Share on other sites More sharing options...
robdyck Posted June 24 Share Posted June 24 1 hour ago, ACADuser said: How do you mix flat soffits & sloped soffits in the same roof plane? This would require manual modelling as there are no soffit settings on a 'per wall' basis. You could either use multipl roof planes, or a single roof plane with manually modeled soffits. Link to comment Share on other sites More sharing options...
ACADuser Posted June 24 Author Share Posted June 24 Thanks for confirming Robert. Link to comment Share on other sites More sharing options...
