decorators3 Posted June 23, 2025 Share Posted June 23, 2025 When I changed my deck sizing . the rails and steps moved but the decking itself stayed in place. any suggestions? Thanks Levina Link to comment Share on other sites More sharing options...
Chrisb222 Posted June 23, 2025 Share Posted June 23, 2025 1 hour ago, decorators3 said: When I changed my deck sizing . the rails and steps moved but the decking itself stayed in place. any suggestions? You probably have "Automatically regenerate deck framing" unchecked in the Deck room dialog. Check the box and the decking will follow the railing.... and also regenerate all of the deck framing. Link to comment Share on other sites More sharing options...
decorators3 Posted June 23, 2025 Author Share Posted June 23, 2025 15 minutes ago, Chrisb222 said: You probably have "Automatically regenerate deck framing" unchecked in the Deck room dialog. Check the box and the decking will follow the railing.... and also regenerate all of the deck framing. Thank you Chris. all fixed Link to comment Share on other sites More sharing options...
