Crazy Walls Issue - Any Help would be great!
EMDesigner33
43 minutes ago, para-CAD said:
You might have a roof or ceiling plane that is too low
I figured it has something to do with the roof, but I never changed anything except for I typically remove the roof and any parts when doing kitchens/baths. I will go back in and look again. Thx.
8 minutes ago, DBCooper said:
Walls can get cut off by roofs and ceilings (even if you made them invisible), stairs, or manually edited to be like this.  Probably best to post your plan if you can figure it out.
I do typically remove the roof and parts when doing kitchens/baths. I will post the plan if I can't figure it out. Question...how do I post it? Still figuring all of this out. I've come a long ways..but there is a LOT! :)
What type of file do I export in order to attach it here?
Most plans are too big to attach directly to the forum.  I usually make a copy, strip things out that aren't part of the problem, and make a compressed archive (zip) to post.  Need to make sure the plan isn't open when you make the zip or it won't work.  Sometimes even that won't work so you need to put the file up on the cloud and post a link to the download.
