Branden Posted June 5, 2025 Share Posted June 5, 2025 Looking for a way to add Stone vent blocking to a dugout that is getting built. I am adding an image of the blocks that are to be used in the build. I need to add them to the top of the dugout walls for ventilation but am unable to find a model or the best way to go about it. Any advice is appreciated. Thank you Link to comment Share on other sites More sharing options...
Hoff_Design Posted June 5, 2025 Share Posted June 5, 2025 Draw the shape to scale in 2D CAD mode then convert to it a polyline solid, give it a height. Apply a concrete texture to it and then save to your library. Or create a 3d solid and make holes in it for the triangles? Link to comment Share on other sites More sharing options...
DBCooper Posted June 5, 2025 Share Posted June 5, 2025 You could create a block symbol that "inserts into wall" and then just place them manually in the wall. Link to comment Share on other sites More sharing options...
Hoff_Design Posted June 5, 2025 Share Posted June 5, 2025 Here is what the block would look like Link to comment Share on other sites More sharing options...
Branden Posted June 5, 2025 Author Share Posted June 5, 2025 Thank you for the responses. I will try these once I am able to. They should work no problem from what I can tell I was just drawing a blank for a moment Link to comment Share on other sites More sharing options...
