KacyRSC Posted May 21 Share Posted May 21 Long time Chief user and residential designer, but I'm new to Chief x17. I'm struggling to figure out how to transfer Projects between two computers. I do a lot of remote work, so this ability is essential. Issue is: I work on a project on PC 1 (a desktop). When I'm finished, I save and export the project file to a flash drive/google drive or whatever. Then, I go to PC 2 (a laptop) and import the project. All seems well, except now I now have multiple versions of the same project (Project A, Project A(1), Project A(2), etc..) showing up in my project browser, and I am also getting broken links to cad details, and none of my work is transferring. Seems like Chief is confused and is loading up older plans and layout pages that were in a previously saved project file with the same name. I tried renaming the project file, which didnt work. I tried manually deleting the redundant projects from the project browser. I tried exporting/copy/pasting the entire matching file structure (my old method) and overwriting the plans, layout pages, and project files. That didn't work either. I'm at a bit of a loss here. Any insight would be greatly appreciated! Edit: Sorry if this post is a bit redundant. Seems like maybe I just need to turn off project management. Link to comment Share on other sites More sharing options...
KacyRSC Posted May 21 Author Share Posted May 21 Seems like one needs to use the new Backup and Restore feature. Going to try this today. Link to comment Share on other sites More sharing options...
ClintonM Posted May 21 Share Posted May 21 3 hours ago, KacyRSC said: All seems well, except now I now have multiple versions of the same project (Project A, Project A(1), Project A(2), etc..) showing up in my project browser, and I am also getting broken links to cad details, and none of my work is transferring. Seems like Chief is confused and is loading up older plans and layout pages that were in a previously saved project file with the same name. While I would expect importing the same project multiple times to produce duplicates in the Project Browser, it should not cause broken links or fail to transfer your work. Please contact our tech support team (https://www.chiefarchitect.com/support/) so that we can gather more information and get this issue resolved. Link to comment Share on other sites More sharing options...
KacyRSC Posted May 22 Author Share Posted May 22 Thanks for the reassurance, Clinton, I thought I was losing my mind because I wasn't having any problems exporting and importing project files from multiple PC's earlier in the week... Ill reach out to support today, and provide an update to help anyone else who may be having issues. 1 Link to comment Share on other sites More sharing options...
KacyRSC Posted May 27 Author Share Posted May 27 Update: For now, it seems like if you consistently switch workstations your best bet is to just disable Chiefs new project management feature. I've tried everything from importing .caproj files to restoring a project from backup, to overwriting the entire Data folder, and my desktop refuses to acknowledge the most recent project file. Hopefully this is something that works seamlessly in the future! Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 27 Share Posted May 27 1 hour ago, KacyRSC said: Update: For now, it seems like if you consistently switch workstations your best bet is to just disable Chiefs new project management feature. I've tried everything from importing .caproj files to restoring a project from backup, to overwriting the entire Data folder, and my desktop refuses to acknowledge the most recent project file. Hopefully this is something that works seamlessly in the future! you can simply import a plan file. it doesnt need to be a caproject file Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted May 29 Share Posted May 29 @KacyRSC Rene is correct on only dealing with a plan file if you want, but I am also working with the Project Manager and really like it a lot. However, the very thing you are looking to do is what I am trying to bring attention to... Check it out and support this and/or offer some ideas. Link to comment Share on other sites More sharing options...
amyondesign Posted August 26 Share Posted August 26 How can two people work on the same files? We have two people who need to work on different parts of a project from two different computers (obviously). Is there a way to have the project management saved onto dropbox or google drive instead of a local desktop? Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 26 Share Posted August 26 5 minutes ago, amyondesign said: How can two people work on the same files? We have two people who need to work on different parts of a project from two different computers (obviously). Is there a way to have the project management saved onto dropbox or google drive instead of a local desktop? Export your project to Dropbox and sharit..just keep in kind you may want to delete the project from project management after you export since it will be an outdated copy once your colleague imports and works on it Link to comment Share on other sites More sharing options...
